Apple iPhone (все поколения, объединенная тема)
Re: Apple iPhone (все поколения, объединенная тема)
Сообщение milch » Вт сен 20, 2016 12:57
Andr3y писал(а):milch
где ты это все выкопал? :facepalm:
Про нагрев вообще впервые читаю. Модемы пользователя волновать вообще не должны, какая разница, что внутри, если оно работает. Про дисплей тоже смешно. Читай http://www.displaymate.com/iPhone7_ShootOut_1.htm
the iPhone 7 has Two Standard Color Gamuts, the new DCI-P3 Wide Color Gamut that is used in 4K UHD TVs and Digital Cinema, and also the traditional smaller sRGB / Rec.709 Color Gamut that is used for producing most existing consumer content for digital cameras, TVs, the internet, and computers, including photos, videos, and movies. What’s more, on the iPhone 7 both Color Gamuts have been implemented with Absolute Color Accuracy that is Visually Indistinguishable from Perfect. That’s impressive... Plus only three manufacturers currently have the new wider DCI-P3 Color Gamut on their Smartphones or Tablets, so it is a major competitive advantage. Other manufacturers will need to play catch-up fast...
Each display is individually calibrated at the factory. The iPhone 7 has a very accurate 102 percent of the wide DCI-P3 Wide Color Gamut and a very accurate104 percent of the sRGB / Rec.709 Color Gamut
In addition, the iPhone 7 detects content marked with the wider DCI-P3 Color Gamut and automatically switches between Gamuts so that content with the smaller sRGB / Rec.709 Gamut is accurately reproduced and not displayed with over saturated colors.
It is the most color accurate display that we have ever measured. It is Visually Indistinguishable From Perfect, and is very likely considerably better than any mobile display, monitor, TV or UHD TV that you have
Звук в комплектных ушах такой же как и раньше только чуть-чуть громче. Глупо рассчитывать, что с телефоном будут класть хай-фай ушки.
Шипение - пока выявлены единичные случаи.
4ПДА читай :wink:
Сообщение Andr3y » Вт сен 20, 2016 13:11
И сколько на 4пда реальных юзеров 7? :lol:
Короче, все ясно, сборник слухов
Andr3y
Сообщение milch » Вт сен 20, 2016 13:12
Решив отказаться от использования аудиопорта в iPhone 7 и iPhone 7 Plus, Apple вынуждена была как-то решить вопрос с совместимостью штатных наушников EarPods. Решив не заморачиваться, инженеры попросту переделали порт гарнитуры: вместо привычного 3.5-миллиметрового штекера пользователя iPhone 7 и iPhone 7 Plus ждет Lightning.
Но это не единственное изменение. Теперь EarPods контактируют с цифровым выходом вместо аналогового, а значит — добро пожаловать в мир багов.
Сразу несколько новоиспеченных владельцев iPhone 7 и iPhone 7 Plus отмечают, что гарнитура EarPods в связке со смартфоном ведет себя крайне странно. Во время использования миниатюрный пульт управления (с клавишами громче, тише, пауза) отказывается работать.
EarPodsBugIn1
Нельзя вызвать Siri, нельзя ответить на звонок, переключить песню или поставить паузу: музыка продолжает играть, а вот пульт наушников работать отказывается. Проблема наблюдается случайно и не привязана к какой-либо закономерности.
Для лечения такого бага достаточно вытащить EarPods из порта Lightning, а затем повторно подключить. Apple обещает устранить данный баг с выходом ближайшего обновления iOS 10.
Сообщение milch » Вт сен 20, 2016 13:19
Андрюха но они же есть.И с загранки тоже юзеры пишут.а то что ты прислал-отписки :lol: :P
а в целом у 7и все хорошо, прекрасная маркиза..
Сообщение Andr3y » Вт сен 20, 2016 13:26
Миша, вышеописанное - баг софта, это ж не хардверная проблема.
Я тебе ссылку кинул на чуваков, которые в лабораторных условиях тестируют дисплеи и выводы там намного более объективные, чем какого-то васи пупкина, для которого эталоном может служить с-амолед дисплеи гнусмаса :wink:
Andr3y
Re: iPhone 6S (а так же новинка iPhone 7)
Сообщение alex_xel » Вт сен 20, 2016 16:19
Dr.House писал(а):Изображение
Сообщение VIKON » Ср сен 21, 2016 13:04
вроде не было ещё...
macOS Sierra - 36 изменений и новых функций.
Самый полный обзор
1. Siri
Первое, с чем сталкивается пользователь после установки macOSSierra — предложение с включением голосового ассистента Siri. Да, теперь он есть не только на #iOS -устройствах, но и на Mac.
Все, что вам нужно — согласиться с использованием #Siri. Вызвать ассистент можно с помощью комбинации клавиш Option + Пробел (по умолчанию)
2. Совместное редактирование заметок
Этого пользователи ждали очень давно и с выходом новой ОС редактировать заметки можно совместно. Достаточно добавить нового пользователя, указав его электронный адрес почты, либо выслав приглашение.
Где найти: В приложении Заметки обратите внимание на новую пиктограмму на панели инструментов.
3. Управление местом на диске
Сторонние клинеры и чистильщики системы — хороший вариант для разгрузки системного диска, но #Apple наконец выпустила собственное, вшитое в систему, решение. Теперь все файлы как на ладони.
Где найти: Откройте системное меню (логотип яблока в верхнем левом углу) —> Настройки, перейдите на вкладку Хранилище и выберите пункт Управлять.
4. Новые обои
Классическое изменение без которого не обходится ни один программный релиз Apple. В этот раз завезли всего двое новых обоев.
Где найти: Откройте Настройки —> Рабочий стол и заставка. Обои Сьерра-Невада и Сьерра-Невада 2 в вашем распоряжении.
5. Пункт Диктовка
Пункт Диктовка, который позволяет вводить текст с помощью голоса, Apple решила переместить из меню настроек немного глубже.
Где найти: Откройте Настройки —> Клавиатура и перейдите на вкладку Диктовка.
6. Перемещение иконки загрузочного тома
Незначительное и чисто косметическое изменение: пункт меню Загрузочный том (позволяет выставить приоритет загрузки ОС на Mac) в меню Настроек переместили на новую позицию.
7. iCloud: оптимизация хранилища
Одним из ключевых нововведений macOS Sierra стала плотная интеграция облачного хранилища #iCloud с системой. Сэкономить пространство на диске можно при помощи выгрузки файлов в облако. В новой ОС для этого предусмотрен дополнительный пункт.
Где найти: Откройте Настройки —> iCloud и, при необходимости, установите галочку напротив пункта Папки «Рабочий стол» и «Документы».
Осторожно! Во включения данной функции между серверами Apple и вашим Mac идет активный обмен данных. Если вы работаете с мобильного интернета, есть риск просадить весь трафик.
8. Перемещение App Store
Незначительное и чисто косметическое изменение: пункт меню #AppStore (позволяет выставить приоритет загрузки ОС на Mac) в меню Настроек переместили на новую позицию.
9. Настройки Siri
Выход полноценной версии голосового ассистента Siri для #Mac не мог обойтись без сопутствующего меню настроек. С его помощью вы можете выбрать новый голос ассистента (женский/мужской), назначить горячие клавиши для вызова ассистента, настроить источник звука.
Где найти: Откройте Настройки —> Siri.
Интересный момент: После включения голосового ассистента вас ждет отвратительный роботизированный голос. Женский или мужской — не имеет значения. Наберитесь терпения и забудьте об ассистенте на несколько часов (не выключайте Mac). Через время запустите ассистент повторно и вы удивитесь качественно новому голосу Siri.
10. Новый цветовая схема Центра уведомления
Вместо черной цветовой схемы Apple решила окрасить Центр уведомлений в светлый свет. Смотрится непривычно, но глаза не режет.
Где найти: Проведите двумя пальцами по трекпаду справа налево (начинайте движение с корпуса ноутбука), либо тапните по соответствующему пункту в верхнем правом углу.
11. Новый стиль уведомлений
Каждое уведомление теперь выглядит в стиле с #iOS10. Крупные прорисованные диалоги вместо мелких строчек, использующихся в прошлых версиях OS X.
Где найти: Откройте Центр Уведомлений.
12. Safari: Apple Pay
В macOS Sierra появилась возможность оплачивать покупки в интернете при помощи сервиса #ApplePay. Это удобно, быстро и не требует постоянных мучений со вводом номеров кредитных и банковских карт.
Для авторизации необходимо использовать #AppleWatch или #iPhone.
Где найти: Если у вас настроен Apple Pay, откройте браузер Safari. Перейдите в Настройки —> Конфиденциальность и установите галочку напротив пункта Веб-сайты могут проверять, доступен ли Apple Pay.
13. Safari: масштабирование страниц
В браузере #Safari появился новый пункт, который позволяет установить масштаб веб-страниц. При этом распространяется масштабирование сразу на все сайты.
Где найти: Откройте браузер Safari. Перейдите в Настройки —> Дополнения и установите желаемое значение напротив пункта Масштаб страницы.
14. Новый iTunes
Обновленный плеер #iTunes Apple представила еще на прошлой неделе. Полный редизайн #AppleMusic пошел приложению на пользу: крупные иконки, большой шрифт. С подробным списком изменений новой версии iTunes можете ознакомится тут.
15. Карты: вкладки
В приложении карты появился режим вкладок. Теперь вы можете прокладывать сразу несколько маршрутов, не сбивая пункты отправления/прибытия. Практично и удобно.
Где найти: Откройте приложение Карты. Перейдите в Файл —> Новая вкладка.
16. Карты: переключатель режимов
Интерфейс приложения Карты остался без кардинальных изменений, но все же Apple внесла незначительные коррективы. Режим отображения карт из кнопочного заменили на выпадающий список.
17. Дополнительное меню в Контактах
Apple продолжается выдерживать свою стационарную операционную систему в стиле iOS, совершенствуя единую экосистему. В приложении Контакты появилась обновленная строка меню: Сообщение, Позвонить, Видео, Почта.
Где найти: Откройте любой контакт из одноименного приложения.
18. Календарь стал «умнее»
Среди нововведений, которые получило штатное приложение Календарь: возможность отображения событий, которые найдены в сторонних приложениях, а также использование карт для определения мест проведения предстоящих мероприятий.
Где найти: Действует система автоматического поиска внутри системы. Найденные события автоматически отображаются в Календаре.
19. Воспоминания в приложении Фото
Функция, которой так гордится Apple. Благодаря Воспоминаниям, ставшими единым целым с приложением Фото, вы можете быстро создать интерактивный фильм-подборку, в который войдут фотографии и видео, приуроченные к какому-либо событию. Музыка и надписи генерируются автоматически. Пользователю необходимо лишь внести косметические коррективы.
Где найти: Новая вкладка Воспоминания в приложении Фото.
20. Иконка редактирования фото
Косметическое изменение: вместо кнопки Редактирование Apple удосужилась нарисовать полноценную иконку. После нажатия вы будете перенаправлены в привычное меню редактирования изображения.
Где найти: Откройте любую фотографию в приложении Фото и обратите внимание на указанную на скриншоте клавишу.
21. Умный поиск фото
Поиск фотографий в приложении Фото стал еще умнее. Найти соответствия любой фотографии можно при помощи одного щелчка по клавише Подробнее. При подборе похожих картинок учитывается геопозиция, дата и время съемки, цветовая гамма.
22. Новые миниатюры фото
Миниатюры фотографий переехали из бокового меню вниз. Снова намек на целостность с мобильной операционной системой #iOS.
Где найти: Тапните по соответствующей пиктограмме в режиме просмотра фотографий.
23. Синхронизация Фото с календарем
В приложении Фото появилась функция включения праздничных событий и их привязка к функции Воспоминания.
Где найти: Откройте приложение Фото. Перейдите в Фото —> Настройки включите галочку напротив пункта Воспоминания: Показывать праздничные события.
24. Новые смайлы
Вместо традиции добавлять новые смайлы, Apple решила перерисовать старые. Выглядят новые Эмодзи объемнее. Может быть мы скоро вновь вернемся к скевоморфизму?
Где искать: Например, в iMessage.
25. Ссылки в iMessage
На iOS именно приложение Сообщение стало чуть ли не гвоздем всего обновления. Для macOS Sierra Apple тоже добавила несколько приятных сюрпризов. Отправленные в iMessage ссылки и музыка отображаются в виде интерактивного превью.
Где найти: Отправляйте ссылки и музыку в приложении iMessage.
26. Новые пункты в Настройках Finder
В связи с внедрением функции Оптимизации хранилища за счет экспорта файлов в облачное хранилище iCloud, в настройках штатного файлового менеджера Finder появилось сразу несколько пунктов.
Где найти: Откройте Finder. Перейдите в Finder —> Настройки.
27. Папки Вверху
Эта функция включается в тех же настройках штатного файлового менеджера Finder и является одной из самых долгожданных среди пользователей компьютеров Mac. При выборе сортировки файлов По имени и включенной функции Сортировки папок, все папки будут отображаться приоритетно.
Где найти: Откройте Finder. Перейдите в Finder —> Настройки. Включите галочку напротив пункта При сортировке по имени отображать папки сверху (см. пункт 26).
Обратите внимание: данная функция не работает при отображении файлов в виде Списка.
28. Быстрый доступ к источникам воспроизведения
Быстрое переключение аудиовыходов — еще одна полезная фича новой системы. Теперь не нужно переходить в настройки и искать нужный источник воспроизведения.
Где искать: Просто тапните по значку динамика в Меню баре (включить пиктограмму динамика можно, открыв Настройки —> Звук и выставив галочку напротив пункта Показывать громкость в строке меню).
29. Перемещение иконок в Меню Баре
Перемещать иконки Меню бара можно было и раньше, но исключительно для штатных приложений. Теперь же можно менять местами и иконки, которые идут в комплекте с приложениями сторонних разработчиков.
Как переместить: Зажмите клавишу CMD на клавиатуре и начните перемещать иконки, зажав клавишу мыши.
30. Вкладки для новых окон
Одна из неочевидных, но невероятно полезных функций, которая появилась в новой системе. Открытие документов во вкладках удобно в офисных приложениях, вроде: #Pages, #Numbers, #Keynote. Создавая новый документ вы можете избавиться от докучающих окон, а организовать рабочее пространство подобно вкладкам в браузере.
Где искать: Откройте Настройки —> Dock и выберите вариант Открытия документах во вкладках. Предусмотрена работа как исключительно в полноэкранном режиме, так и в оконном.
31. Добавление точки двойным пробелом
Функция, которая уже несколько лет есть в мобильной операционной системе iOS. Теперь достаточно нажать два раза пробел, как в конце слова или фразы будет автоматически поставлена точка.
Еще одно дополнение — автоматическая установка заглавной буквы после точки.
Где найти: Откройте Настройки —> Клавиатура и включите соответствующий галочку.
32. Картинка в картинке
Впервые функция картинка-в-картинке появилось на #iPad. Теперь ей обзавелся и браузер Safari. При воспроизведении видео достаточно нажать всего одну клавишу, после чего видео будет отображаться поверх любых открытых окон.
Где найти: Например, на сайте Apple. Работает ограниченно и находится в стадии бета-тестирования.
33. Управление мышью с помощью головы и глаз
Для людей с ограниченными возможностями Apple интегрировала функцию управления мышь при помощи движения головы или глаз Dwell Control.
Где найти: Откройте Настройки —> Универсальный доступ. Прокрутите боковой список в самый низ до пункта Dwell Control.
34. Автоблокировка с помощью Apple Watch
Если вы являетесь счастливым обладателем смарт-часов #AppleWatch, то после установки macOS Sierra для разблокировки Mac вам достаточно будете поднести носимый аксессуар к экрану компьютера. Срабатывает моментально.
35. Файловая система APFS
В macOS Sierra Apple решила использовать собственную файловую систему APFS. У нее есть немало преимуществ:
Единая система для всех продуктов (включая iPhone, Apple Watch, #AppleTV) Максимально оптимизирована конкретно под устройства компании. Имеет более высокую степень защиты
Системе предвещают успех и значительное повышение быстродействия устройств Apple, обновившихся до ОС на базе APFS.
36. Универсальный буфер обмена
Выпустив macOS Sierra Apple автоматически сделала бесполезными десятки приложений в магазине Mac App Store. Речь идет об универсальных буферах обмена. В качестве дополнения к Continuity компания интегрировала Универсальный буфер обмена.
Скопировали текст на Mac — вставьте его на iOS. И наоборот.
Где найти: Искать нигде не нужно. Просто убедитесь, что ваш Mac и iOS-устройства работают под одной учетной записью iCloud.
Это практически все изменения, которые нам удалось обнаружить в #macOSSierra.
Сообщение zav » Ср сен 21, 2016 13:24
ну шо? кто то купил? :D
Тридцатьшестой :)
zav
Сообщение Dr.Klim » Ср сен 21, 2016 15:36
А от цікаво, в 7ки є функція карти без доступа до інтернету, через GPS? Дуже зручна штука, коли їдеш за кордон. І шлях прокласти можна і за трафік не сплачуєш.
Чемпіон Європи.
Dr.Klim
Сообщение Andr3y » Ср сен 21, 2016 15:40
Dr.Klim
Есть. maps.me и еще 100500 разных вариантов карт, работающих БЕЗ интернета
Andr3y
Сообщение Dr.Klim » Ср сен 21, 2016 15:52
Andr3y писал(а):Dr.Klim
Все! Беру!
Чемпіон Європи.
Dr.Klim
Сообщение VIKON » Ср сен 21, 2016 19:11
руслики написали про 7-ку - https://ru.insider.pro/technologies/201 ... n=boost_ru
Сообщение Dr.Klim » Пт сен 23, 2016 05:57
Все! Беру!
Мабуть почекаю ще )
Некоторые пользователи iPhone 7 и 7 Plus жалуются на плохое качество звука во время телефонного звонка
http://www.macdigger.ru/iphone-ipod/nek ... um=twitter
Чемпіон Європи.
Dr.Klim
Сообщение Andr3y » Пт сен 23, 2016 09:10
Dr.Klim
На полпути за айфоном остановился? :ROFL:
Andr3y
Сообщение VIKON » Пт сен 23, 2016 10:14
Dr.Klim писал(а):Мабуть почекаю ще )
Димка, ждать не долго :D
http://www.vedomosti.ru/technology/news ... one-za-130
