Продам турбину BorgWarner EFR6758 0.8 A/R IWG T4.
Сообщение it_manager » Чт май 28, 2015 22:25
Продам новую турбину BorgWarner EFR6758 IWG 0.80 A/R T4
Горячка покрыта керамическим покрытием черного цвета.
Цена в США - $1633 + $429 (T4) + $85 (Ceramic coating). + Доставка.
Моя цена - $1750.
О6семь ПятьОДва 3223.
The EFR 6758 is a remarkably versatile turbocharger, packaged in the compact B1 EFR frame. The compressor offers broad map width for outstanding power potential in a variety of applications from rally, drift, road racing, autocross, drag and street driven applications. This FMW compressor wheel measures 53.9mm inducer with 67mm OD compressor to support a 53lb/min max flow rate. The EFR 58mm turbine wheel is made of Gamma-Ti for low inertia and an optimal match for the FMW compressor wheel. Ideal for use in single turbo applications for the 300-450whp range, or as twin turbo applications 550-900+whp. Ceramic Ball Bearing only, watercooling recommended.
Compressor Specifications
Compressor Type: Forged-Milled Wheel (FMW) Extended Tip
Compressor Wheel OD (exducer): 67mm
Compressor Wheel Inducer: 53.9mm
Max Flow Rate: 53 lb/min
Built-in BOV: All EFR compressor housings incorporate an integrated BOV.
Compressor Housing: 2.5" inlet, 2.0" hose coupler outlet
Turbine Specifications
Turbine type: Low Inertia Gamma-Ti Turbine Wheel
Turbine Wheel OD: 58mm
Stainless Steel Sand cast Housing
0.64 A/R T25 Undivided (Internal WG) - Part # 179388
Turbine outlet: GT-Vband (aka small 3" vband) ~92mm OD for all EFR turbos
Подробнее тут - http://www.full-race.com/store/efr-turb ... rbo-2.html
it_manager
