Subaru Impreza WRX STI 2003
Сообщение darkit » Пн окт 19, 2015 15:13
Цена 16000$
Телефон: +38-097-699-44-61
Изменения:
Engine:
EJ207
Kelford Cams V2-199-C Camshaft (Subaru JDM Version 7-10 EJ20 w/AVCS)
Brian Crower Valve Springs & Titanium Retainer Kit
ACL Race Main & Rod Bearings
MANLEY Connecting Rods Forged H-Beam
JE Pistons 92.5mm 8.5:1 CR
ARP 260-4701 Cylinder Head Stud Kit
GATES Racing Timing Belt
High Performance Oil Pump
HARDRACE Engine Mounts & Transmission Mount
Carbon Oil Reservoir Catch Tank Grimmspeed
Mishimoto Performance Silver Oil Cooler Kit + Termostat
Mishimoto Performance Aluminum Radiator + 1.3 Bar cap
Samco silicone Hoses Blue
Turbo:
Subaru custom Rotated Intake Manifold Tuned by Viktor Soara
Forced performance Green HTA Turbine Housing 8cm
TurboXS FMIC Front Mount Intercooler Kit Tuned by Viktor Soara
Tial Q 50mm Blow Off Valve BOV RED
Kakumei Exhaust Manifold Header V-band Tuned by Viktor Soara
Kakumei Catback Exhaust
TiAL MV-SR 38mm Wastegate Red With V-Band and Flanges
Samco Turbo Charger Inlet Intake Silicone Hose Arm
K&N Dry AIR Filter
Fuel:
Perrin Performance Top Feed Fuel Rail Kit
1000cc FIC Fuel Injector Clinic Injectors
WALBRO 255LPH FUEL PUMP
Gauge:
UTEC TURBO XS PIGGY BACK ENGINE COMPUTER ECU + MAP sensor Tuned by Bilyk WRX
SNOW PERFORMANCE STAGE 2 TWO WATER METH METHANOL INJECTION KIT BOOST COOLER
DEFI GAUGE 60mm Oil temp
DEFI GAUGE 60mm Oil pressure
DEFI GAUGE 60mm Fuel pressure
DEFI GAUGE 60mm Exhaust temp
AEM 30-4110 DIGITAL WIDEBAND UEGO CONTROLLER AIR FUEL RATIO KIT
HKS EVC Boost Controller 6th Generation (A-1.5bar, B-2bar of boost)
Brake:
ZeroSport Stainless Steel Braided Brake Lines
Brembo [FRONT + REAR] PREMIUM Drilled Slotted Brake Disc Rotors
Ferodo DS2500 Racing Front & Rear Brake Pads
Drivetrain:
RalliSpec 2nd-6th Long Ratio Gear Kit (The top speed in each gear is raised 6% for 2nd gear, 16% in 3rd gear, 18% in 4th gear, 9% in 5th gear, and 7% in 6th gear. So, for example, in 6th gear if your current top speed is 175mph the new top speed would be 175*1.07 = 187mph.)
DSS (R180 Rear) 1-Piece Carbon Fiber Driveshaft (This driveshaft is rated to 850WHP and a top speed of 180MPH )
ACT Xtreme Duty Performance Street Disc Clutch Kit
ACT StreetLite Flywheel
Kartboy Short Throw Shifter
Kartboy Front Shifter Bushings
Kartboy Rear Shifter Bushings
Suspension:
KYB AGX Adjustable Shocks Front & Rear
Cusco Front Strut Bar
Cusco Rear Strut Bar
CUSCO SWAY Bar 22MM,Front, Rear
Exterior:
Volk Racing Wheels Rims TE37 18
ings+ N-SPEC IMPREZA GDB(APPLIED Type:F) FRONT BUMPER, SIDE STEPS, REAR BUMPER
Kakumi REAR Spoiler Wing
Последний раз редактировалось darkit Пн окт 19, 2015 18:55, всего редактировалось 2 раз(а).
SUBARU FORESTER 2.5Т АТ 2009г.
darkit
Re: Subaru Impreza WRX STI 2003
Сообщение rymun » Пн окт 19, 2015 18:40
Error (403) на фоточки
rymun
Сообщение darkit » Пн окт 19, 2015 18:55
rymun писал(а):Error (403) на фоточки
поправил
darkit
Сообщение SFQ IX » Ср окт 21, 2015 19:16
Можно на понятном языке? Кто, что, пробег, мощность, момент, где и когда собирали, кто настраивал, квотер, 100-200, динамика, в общем? Фото салона, мотора...
SFQ IX
Сообщение darkit » Чт окт 22, 2015 15:30
SFQ IX писал(а):Можно на понятном языке? Кто, что, пробег, мощность, момент, где и когда собирали, кто настраивал, квотер, 100-200, динамика, в общем? Фото салона, мотора...
Машина модератора одесской ветки Joy-я. Собирал он её на Сто одесском моримото. Настраивал Билык. Квотеры и т д не замерялись так как машина не для гонок а для удовольствия. По мощности можно спросить у Билыка он настраивал. Где то 500 на маховике не меньше.
darkit
Сообщение SFQ IX » Пт окт 23, 2015 09:16
500 на грине? Фото и пробег тоже у Билыка? Инфа не читабельна, совсем.
SFQ IX
Сообщение JOHNNY_G » Пт окт 23, 2015 13:25
1) 500 на Грине ???
2) можно фото салона.
3) пробег общий и после капиталки.
SG9,VF35,STRI,TurboXS DELTA UTEC,AEM UEGO,MOCAL Oil Cooler,STI intercooler,Walbro,Cusco 24mm,Kakumei Front\Rear\brace bar STi,Silence MeganRacing,HKS EVC6,STI 18x8.5,BREMBO GOLD 4pot\2pot,Mishimoto Radiator,AEM water-metanol,ALPINE 2 kWt /Tuned by Mad Max
JOHNNY_G
Сообщение Orest » Пт окт 23, 2015 17:46
Довго тримався і дуже хотів задати питання про Грін і 500кс)))))
My WRX f@cks your STI ...:)
Orest
Сообщение JDS » Пт окт 23, 2015 18:24
И что за спойлер? Это просто капец какой-то :lol:
JDS
Сообщение exigo » Пт окт 23, 2015 18:40
Orest писал(а):Довго тримався і дуже хотів задати питання про Грін і 500кс)))))
Хм...на моем эвике на этой турбе с надуввом 2.0 бара как раз и показало 504 л.с.
На данном авто есть валы, пигибек, метанол и тот же наддув 2.0. В принципе все реально
exigo
Сообщение zhekab4 » Пт окт 23, 2015 20:41
субару-клуб.теоретик.ком короче :)
ехала хорошо год назад
спойлер сток.стоят проставки какумей
Сообщение darkit » Пт окт 23, 2015 21:53
JOHNNY_G писал(а):1) 500 на Грине ???
1) На грине hta 8см и валы и метанол
2) завтра днем сделаю
3) сейчас 185тыс, после капиталки (2 года назад делал еще Костя) проехала тыс 15. Катаюсь мало - основная акура и та за 5 лет проехала 32тыс миль.
darkit
Сообщение darkit » Пт окт 23, 2015 21:54
JDS писал(а):И что за спойлер? Это просто капец какой-то :lol:
снимешь проставки и будет сток. но в живую он отлично смотрится.
darkit
Сообщение darkit » Вс окт 25, 2015 11:55
Фото салона и мотора
darkit
Сообщение darkit » Ср дек 23, 2015 14:33
Тк ажиотаж небывалый - то отдаю за 15000$
darkit
