Карта Украины на штатный NAVI
Re: Карта Украины на штатный NAVI
Сообщение aratta » Вт апр 16, 2013 14:41
аутбек 2004 рік, 3.0. Скачав образ карт вольво, записав на швидкості 4х програмою imageburn, book type: dvd-rom. засунув диск в машину, зняв клєми + з акума на 1 хв, включаю - навігатор пише вставте коректний диск......
що робити ?
лог запису
I 14:07:02 ImgBurn Version 2.5.7.0 started!
I 14:07:02 Microsoft Windows 7 Ultimate x64 Edition (6.1, Build 7601 : Service Pack 1)
I 14:07:02 Total Physical Memory: 8 275 440 KB - Available: 5 951 968 KB
W 14:07:02 Duplex Secure's SPTD driver can have a detrimental effect on drive performance.
I 14:07:02 Initialising SPTI...
I 14:07:02 Searching for SCSI / ATAPI devices...
I 14:07:02 -> Drive 1 - Info: DTSOFT BDROM 1.05 (G:) (Virtual)
I 14:07:03 -> Drive 2 - Info: HL-DT-ST DVDRAM GH24NS95 RN00-J0 (E:) (SATA)
I 14:07:03 -> Drive 3 - Info: NGVQVE 7WLIZS9UB 3.5Z (F:) (SCSI)
I 14:07:03 Found 1 DVD±RW/RAM and 2 BD-ROMs!
I 14:07:46 Operation Started!
I 14:07:46 Source File: D:\скачане\chrome\MMM2_2012_DVD_D\MMM2_2012_DVD_D\464110-9360.ISO
I 14:07:46 Source File Sectors: 3 947 152 (MODE1/2048)
I 14:07:46 Source File Size: 8 083 767 296 bytes
I 14:07:46 Source File Volume Identifier: 464110-9360
I 14:07:46 Source File Application Identifier: Session Offset : 0 VTC Sector Offset: 0
I 14:07:46 Source File Implementation Identifier: Smart Storage, Inc.
I 14:07:46 Source File File System(s): ISO9660; Joliet; UDF (1.02)
I 14:07:46 Destination Device: [5:0:0] HL-DT-ST DVDRAM GH24NS95 RN00 (E:) (SATA)
I 14:07:46 Destination Media Type: DVD+R DL (Disc ID: MKM-003-00)
I 14:07:46 Destination Media Supported Write Speeds: 4x; 8x
I 14:07:46 Destination Media Sectors: 4 173 824
I 14:07:46 Write Mode: DVD
I 14:07:46 Write Type: DAO
I 14:07:46 Write Speed: 2x
I 14:07:46 DVD+R DL Reserve Track: No
I 14:07:46 Link Size: Auto
I 14:07:46 Lock Volume: Yes
I 14:07:46 Test Mode: No
I 14:07:46 OPC: No
I 14:07:46 BURN-Proof: Enabled
W 14:07:46 Write Speed Miscompare! - Wanted: 2 770 KB/s (2x), Got: 5 540 KB/s (4x)
W 14:07:46 The drive only supports writing these discs at 4x; 8x.
I 14:07:46 Book Type Setting: DVD-ROM
I 14:07:46 Optimal L0 Data Zone Capacity: 1 973 584
I 14:07:46 Optimal L0 Data Zone Method: ECC Block Boundary
I 14:07:46 Set L0 Data Zone Capacity Succeeded!
I 14:07:47 Filling Buffer... (80 MB)
I 14:07:48 Writing LeadIn...
I 14:08:28 Writing Session 1 of 1... (1 Track, LBA: 0 - 3947151)
I 14:08:28 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3947151)
I 14:08:28 Writing Layer 0... (LBA: 0 - 1973583)
I 14:20:45 Writing Layer 1... (LBA: 1973584 - 3947151)
I 14:33:15 Synchronising Cache...
I 14:33:18 Closing Track...
I 14:33:19 Finalising Disc...
I 14:33:53 Exporting Graph Data...
I 14:33:53 Graph Data File: C:\Users\andriy\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_DVDRAM_GH24NS95_RN00_16-КВІТЕНЬ-2013-Р-_14-07_MKM-003-00_2x.ibg
I 14:33:53 Export Successfully Completed!
I 14:33:53 Operation Successfully Completed! - Duration: 00:26:06
I 14:33:53 Average Write Rate: 5 308 KB/s (3.8x) - Maximum Write Rate: 5 587 KB/s (4.0x)
I 14:33:53 Cycling Tray before Verify...
W 14:34:00 Waiting for device to become ready...
I 14:34:12 Device Ready!
I 14:34:20 Operation Started!
I 14:34:20 Source Device: [5:0:0] HL-DT-ST DVDRAM GH24NS95 RN00 (E:) (SATA)
I 14:34:20 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: MKM-003-00)
I 14:34:20 Source Media Supported Write Speeds: 4x; 8x
I 14:34:20 Image File: D:\скачане\chrome\MMM2_2012_DVD_D\MMM2_2012_DVD_D\464110-9360.ISO
I 14:34:20 Image File Sectors: 3 947 152 (MODE1/2048)
I 14:34:20 Image File Size: 8 083 767 296 bytes
I 14:34:20 Image File Volume Identifier: 464110-9360
I 14:34:20 Image File Application Identifier: Session Offset : 0 VTC Sector Offset: 0
I 14:34:20 Image File Implementation Identifier: Smart Storage, Inc.
I 14:34:20 Image File File System(s): ISO9660; Joliet; UDF (1.02)
I 14:34:20 Read Speed (Data/Audio): MAX / MAX
I 14:34:21 Verifying Session 1 of 1... (1 Track, LBA: 0 - 3947151)
I 14:34:21 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 3947151)
I 14:34:21 Verifying Layer 0... (LBA: 0 - 1973583)
I 14:40:00 Verifying Layer 1... (LBA: 1973584 - 3947151)
I 14:45:47 Exporting Graph Data...
I 14:45:47 Graph Data File: C:\Users\andriy\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_DVDRAM_GH24NS95_RN00_16-КВІТЕНЬ-2013-Р-_14-07_MKM-003-00_2x.ibg
I 14:45:47 Export Successfully Completed!
I 14:45:47 Operation Successfully Completed! - Duration: 00:11:25
I 14:45:47 Average Verify Rate: 11 541 KB/s (8.3x) - Maximum Verify Rate: 16 796 KB/s (12.1x)
aratta
Сообщение Raiden » Вт апр 16, 2013 15:05
Michael_M писал(а):Просьба помочь - скачал карты, все загрузилось и "начало" работать. Проблема в том, что в разделе navigation set up/navigation information/vehicle signal, где указываются данные со спутника в колонке satellite не отображаются спутники, а просто написано "0", а в полях долготы (longtitude) и ширины (latitude) отображаются данные. Влияет это на то, что текущие координаты авто не определены и, соответственно, невозможно никуда проложить маршрут. Во время движения скорость авто отображается корректно. Начал грешить на GPS приемник, разобрал полмашины и добрался до самого блока - антенна всунута в него. Может, сломался сам GPS приемник? Ни у кого такого не было? С чем может быть связано?
Похоже на железную проблему... Как раз это меню у меня работало всегда. До того, как появились карты, я часто включал этот экран, чтобы видеть точную скорость.
Outback 2.5 2014
(ex Outback 3.0 2005)
Raiden
Сообщение Raiden » Вт апр 16, 2013 15:11
aratta писал(а):аутбек 2004 рік, 3.0. Скачав образ карт вольво, записав на швидкості 4х програмою imageburn, book type: dvd-rom. засунув диск в машину, зняв клєми + з акума на 1 хв, включаю - навігатор пише вставте коректний диск......
що робити ?
Так і має бути після зняття клеми. У цій темі вже не раз було написано, що після зняття клеми необхідно використовувати оригінальний диск, щоб завантажити у навігатор навігаційну програму (вона стирається, коли немає напруги від акумулятора), і тільки після цього вставляти диск із картами. Посилання на образ оригінального диску є вище в темі.
Outback 2.5 2014
Raiden
Сообщение Michael_M » Вт апр 16, 2013 15:21
aratta
aratta
Дело в том, что скорость навигация и так измеряет (без поимки спутников). Нашел антенны по 200 грн - нужно попробовать. Кстати, а кто в курсе где спрятана штатная антенна в субару легаси 2004 г.в.?
Michael_M
Сообщение GanjaMan » Вт апр 16, 2013 16:28
Michael_M писал(а):aratta
aratta
антенна - это обогрев заднего стекла...
GanjaMan
Сообщение Valodia » Вт апр 16, 2013 19:52
aratta
ошыбаетесь , джпс антена расположена за щатком приборов, там ей штатное место. И она совсем другая чем та что возле обогрева. Я свою купил не оригинал, и просто магнитом прилепил на сам монитор, таким образом решыв очень просто где ее прилепить. Правда когда она была открытая на торпеде, ловила немного больше спутников.
Valodia
Сообщение Michael_M » Ср апр 17, 2013 22:29
Ура! После покупки и установки новой антенны, спутники начали отображаться и все заработало. Всем спасибо за помощь и советы, а особенно Valodia за дельные совыты и помощь в поиске и покупке новой антенны.
Michael_M
Сообщение Valodia » Чт апр 18, 2013 07:24
Да незачто! Главное что все заработало, я же говорил что ненадо опускать руки) Только один вопрос, вам также обрезали салазки на штекере антенны?
Valodia
Сообщение Michael_M » Чт апр 18, 2013 08:20
По салазкам: действительно салазки на штекере антенны пришлось срезать - антенна никак не хотела входить в блок навигации.
Michael_M
Сообщение EduardYM » Пт апр 19, 2013 12:17
У меня диск до конца не вставляется. Буд-то упирается во что-то. Хотя там пусто? Кто-то знает почему?
EduardYM
Сообщение maxuss » Вт май 07, 2013 17:19
Поставил вольвовскую карту, съездил в Чернигов.
Если б ехал по навигации, наверное б не доехал или в лес куда...
Где-то не доезжая Козельца потеряли мы трассу Е-95 и привет. :lol:
Потом находили как-то спонтанно и опять теряли.
Посмотрел я на это дело и выключил ее. Может по Киеву или другим трассам будет лучше, надо проверять.
maxuss
Сообщение Raiden » Вт май 07, 2013 19:06
А я вот только что вернулся из-под Севастополя, наездил с этими картами почти 2 тыс. км. Особых нареканий нет, все работало боль-мень нормально, но, как и с любым другим навигатором, лучше внимательно проверять, как проложен маршрут - например, в одном месте в Крыму меня он повел по короткому пути, но через горную грунтовку. В итоге решили ехать и не пожалели, насладились природой :) Но на будущее выводы сделали. По крупным трассам вел хорошо, вообще без проблем. Из того, что впечатлило: знает много мелких дорог в населенных пунктах, в том числе едва заметных грунтовок в селах, и корректно ведет по ним к пункту назначения. Из негатива: в Харькове не знает часть ул. Сумской (главная улица города) - говорит Unknown Road, и привет. Не знает многие номера домов по пр. Гагарина, что тоже удивило. Плохо рассчитывает время прибытия на маленьких маршрутах в пределах города, на длинных при этом все ОК. В общем, после проверки в боевых условиях моя оценка - 7 из 10.
Outback 2.5 2014
Raiden
Сообщение Valodia » Вт май 07, 2013 21:18
Тоже самое и у меня. Ездил по западной Украине , Карпаты, Закарпатье.... Отлично навигатор себя чуствует. Вообщем вполне прилично !
Valodia
Сообщение Raiden » Вт май 07, 2013 21:58
Еще в огромные плюсы карт хочу добавить отличную базу POI. Навигатор знает множество заправок, кафе, отелей, больниц и т.п. Причем часто в базе есть и телефоны всех этих точек, т.е. в случае чего можно обойтись без инета для поиска такой информации.
Например, в дороге бывает необходимо найти какую-нибудь брендовую заправку: жмем выбор пункта назначения, затем Point of interest, пишем Wog, Okko и т.п., получаем список ближайших точек, выбираем нужную - вуаля. Кстати, база не только большая, но еще и довольно новая - например, там есть ресторанчик, который открылся около года назад.
Outback 2.5 2014
Raiden
Сообщение Dionizas » Ср май 08, 2013 20:58
Спосибо за файлы, пoказывает отлично... Но у миня неработает "АДРЕС" меню с этой навигации. Может есть придложение нащиот этого? Я из Литвы, извините за граматику :)
У миня Legacy 2004 Европа
Последний раз редактировалось Dionizas Ср май 08, 2013 21:21, всего редактировалось 1 раз.
Dionizas
